about 7 years ago by José Luis RamÃrez
In food 4 rhino there's only human for rhino 6 :/
José Luis RamÃrez about 7 years ago
Thanks man, yes in deed i tried but there's no backward compatibility with my old rhino version so i guess at some point i have to upgrade but for now i'm fine :)
Hi Jose!
It says it might not work in Rhino 5, have you tried to see if it works? I have to stress that it would be better to upgrade your Rhino to version 6 if possible, if this is not possible AND the version from foodforrhino does not work try the link below.
This is an older version here: https://mega.nz/#!EVs3kITS!M7sz--cGNuhME-ISEz2Kkk0gnWVUjPlUgVqKR3cYB40
Don't forget to unblock the file after putting it in the grasshopper library directory (right click > properties > under the general tab, unblock)
Use https://www.7-zip.org/ to unzip the archive.
