almost 5 years ago by Mush
Hi. I am trying to create and standardize flat panels on a double curved surface. My problem is I am using the Lunchbox component Triangle Panels B or Diamond panels to generate my panels. How do I get closed polyline curves so I can analyze and standardize them like you do. The Weaverbird Dual Graph Component outputs closed polylines but I do not want hexagonal panels. I need triangular closed polylines. Thanks!
Hi Mush,
Please see the attached image. After the "Triangle Panels B" from Lunchbox use the "Brep Wireframe" component to get the edges from the panels and then use a "Join curve" component to join them together to get a closed polyline.
Mush almost 5 years ago
A screenshot showing my problem. The join curves shown here does not work.
