about 5 years ago by Katie
From 6:32 can't we just use Series and pulgin the distance then 50 nos. as counts?
Hi Katie,
I believe Cesar was using this example to explain where loops might be beneficial. Although I agree with you that his example is a bit flawed because you can use a series or range component to circumvent the need for a loop. However there are examples where using Anemone is needed, which I believe Cesar gets into later on.
