Hello, why were the curves (wall lines & division lines) exploded? Is it a good practice to always explode the curves in order to split the surface?
Hi Agneesh!That's a very good question, I'm also not quite sure =) I believe single line segments work a little better (but slower) with the split surface component. You could try to bypass the explode command and directly connect the "start end" point component to the "geometry pipeline" and see if it works, it should I believe.
