about 4 years ago by Esteban Londono
Hi. Regarding the setup of the Grid: wouldn't be easier just to setup Rhino's grid to the dimensions given by the Sketch (i.e.: 1.09 x 1.09) and then scale and align the sketch over the doc's grid; instead of building the grid ourselves? Thank you.
Arie Willem de Jongh almost 4 years ago
Hi Esteban,
Great suggestion! And yes this is also possible to do and quite clever. The reason I created my own grid is that I use the default Rhino grid a lot to snap to, knowing that it's spaced exactly 1 unit apart. For instance when extruding the wall, which I used exactly 3 meters, snapping to the grid this is quite easy. It's baked into my head you might say, so setting it to 1.09 messes with my head =). But this is a personal preference. Try around what works best for you.
