almost 8 years ago by Helen Chong Helen Chong
Hi. May I ask for the value listener component, i can listen to the value of a single element. However, when i combine several components into an expander, it could only return a True/False. Is there any ways that i can listen to the value in each of the items in the expander? Thanks
Hi Helen,
A little late, but I can't reproduce your problem. I've put a button and a value slider and the Value Listener outputs both values in a tree structure. First branch the value as an integer, (integer slider) and the second a True/False, (button)
Could you provide an image of what you're trying to achieve
