almost 9 years ago by Awais Rauf
I am not able to make any selection in Rhino while my Grasshopper window is open. You did it so seamlessly in the video tutorial. Is there a button on the keyboard we need to press while making a selection? Update: I can only select the resulting object after I bake the geometry. But not as you were selcting the points and the surface at 6:00. Thanks.
Mick Des Bois over 8 years ago
Awais Rauf almost 9 years ago
