about 4 years ago by Martina
I mean without the vertical devisions we made. How could we do it wihtout having an issue with the secondary walls while using the boolean split? Would we use another method in this case? .... Actually I tried it and I was able to do it without problem.. So my question is why we didn't do the windows continuous? It seems to me by looking at the building's photos that they are continuous and that the vertical divisions are from the windows' frames? Am I mistaken? Thank you :)
Arie Willem de Jongh almost 4 years ago
Hi Martina,
You're right, there are a lot of ways to achieve this (and probably better ones). I tried to find a method that showed the use of different commands and the Gumball to scale for instance. For me it was more about showing what you can do with the different tools and commands in Rhino than creating an exact copy of the Villa.
