over 5 years ago by Edmondo Rumori
Hi Could you explain how can be export the LadyBug 3d Chart and LadyBug Radiation Analysis color scheme into Illustrator? Will it be possible to export the color scheme as a vector image in order to keep it editable for Illustrator ? Thx.
Hi Edmondo!
The best way to export stuff to Illustrator from Rhino in my opinion is:
1) Bake your geometry you want to export.
2) Use layers as they will be recognized by Ilustrator (colors etc.) Also it's advised to create a layer for "Lines" and a separate one for "Fills/surfaces"
3) Select your geometry and File > Export Selected
4) Select Autocad drawing.DWG from the export and click options and select the 2007 Solids preset
5) In Illustrator open a new file and place your dwg (deselect link form the options)
7) You have to ungroup your geometry a couple of times unfortunately as they're all in their own group, but the layers and colors are preserved.
