almost 7 years ago by Taran Zishan Hossain
I dont know how to fix it
guyfromhills over 4 years ago
did the exact same thing but didn't work dunno why? clearly panel and duplicate data outputs are not getting accepted even after flattening
below i have added the wrong screenshot
Arie Willem de Jongh over 4 years ago
Hi,
I think in your case you have checked the "multiline data" in your panel setting and you have an extra entree below the "0" input that's not visible.
When you entered the 0, you hit enter which created this entree.
See the attached image.
When you have your panel set without multiline data checked, just delete the empty entree and it should function.
Let me know if this worked,
Wael Soliman almost 6 years ago
Same here, u need to uncheck Multiline data in the text numbe.
Jam about 5 years ago
Never mind, solved it
I get the same error. This is the image of the definition
