over 8 years ago by João Victor Mota
Hey there! At the end, when I'm supposed to use I-1 as expression, it doesn't actually works, because I it's a unknow variable . It says "x: Integer" in -Variables- in the Expression Designer, but when using x instead of I, the trick doesn't work and I can't cull out the last two masses at the top of the tower (when I disabled the preview of the extrusions around @12:22 and @12:38, all the masses were gone, and not only the top ones) What should I do?
Mladen over 8 years ago
Walaiporn Nakapan over 7 years ago
