about 5 years ago by Dounia Touil
Hi, I am trying to create floors using the Add Floor component, but the later is not working. The error message I get is: 1. RhinoInside.Revit.GH: The input curve loops cannot compose a valid boundary, that means: the “curveLoops” collection is empty; or some curve loops intersect with each other; or each curve loop is not closed individually; or each curve loop is not planar; or each curve loop is not in a plane parallel to the horizontal(XY) plane; or input curves contain at least one helical curve. 2. Transaction RolledBack and aborted. I have tried to use the Add Roof component and it works fine. Anyone knows what is the problem here? Thanks
Dounia Touil about 5 years ago
I got an answer to my issue on the Rhino Forum. For those experiencing the same issue, the solution is to Graft the curve's data.
Henrique over 2 years ago
Michael, besides grafting the boundary, if you also graft the level then you'll get one floor plate per level.
Michael Westerlund almost 5 years ago
Dounia,
Thanks for updating. However, when grafting it results in 21 floors for each individual curve. Did you experience the same issue? The in-data looks all good with 21 levels and curves and correct data tree.
