about 4 years ago by Daniel Clarke
Hello! I am trying to select items in the lesson assets rhino model in the same way that is demonstrated in the video - currently on the 3D polysurfaces part around 88% of the way through but this is done throughout the whole segment, starting with the "surface cylinder (closed one direction)". It seems like I should be able to select only one polyline but if I try to select in the same way, I just end out selecting the whole object. I am hoping someone can explain what I'm doing differently; did I miss something?
Arie Willem de Jongh about 4 years ago
Hi Daniel,
There are two ways to select sub objects:
