about 5 years ago by Chris Kay
Right around 6:13 you breezily select the 4 corner anchor points with no regard to how you did that. Could you please explain how you made that happen? I cannot select ANY of my grasshopper points from the rhino viewport.
Chris Kay almost 5 years ago
I cancelled my subscription since teachers like Arie don't take this site seriously. Good luck getting an actual answer in a timely manner. And to answer your question: no, I still have not been able to finish this and other tutorials because of my unanswered questions.
Le Maire almost 5 years ago
Hi Arie! Sorry for my English... I have the same problem. I am using Rhino 6 and the "set multiple point" selection seems not to works from the rhino viewport as in the video. I cannot select any point from the mesh.
I looked in the Mcneel forum and this topic appears: https://discourse.mcneel.com/t/set-multiple-points-grasshopper-rhino-6-bug/57762
Do you have a tip to finish this tutorial in an other way?
Thank you very much!
Nicolas
Hi Le Maire,
Thanks for your research, I was not aware of this bug. However, I just tried to replicate the bug and I was able to select the points, soo I thin they fixed it in the latest release. But there's a catch: if you select the points FIRST in Rhino and THEN reference them in the point component in Grasshopper, the order you used to select them is wrong in Grasshopper. Here is a fix, which is basically doing it the other way around:
1) Go to Grasshopper and right-click on the Point component and select "set multiple points"
2) Go to Rhino Canvas and select the points in the order you like
3) Hit enter when done.
Let me know if this worked
Chris Kay about 5 years ago
It took you nearly a month to reply to my question. I would like a refund for that month I paid to wait.
Hi Chris,
If you right click on the Point component and from the dropdown menu select "select multiple points", you should be able to select the points in the Rhino Canvas.
