almost 7 years ago by KK Wong
I dont have t spline can i still do the tutorial?
Joseph over 5 years ago
is the course ready yet? Or some alternative way to learn this couses? thank you!
Hi Joseph,
Not yet, the feature is still in Beta for Rhino 6. When Rhino 7 comes out it should be ready. You still could do the course, only the modeling of the coarse mesh roof will be a bit harder, because you have to use Rhino's native mesh edit and creation tools, which are kind of crappy, but they work. After you've finished the roof use the command "_ToSubd" to convert the coarse mesh to a Subd.
More info on the state of development here: https://docs.google.com/document/d/1BsNLtTj8s0J-7uBuuKDRWJq6VtOLe_WlgPi-oQ7SxoI/edit#
Ale Nicotra over 6 years ago
Have the same problem :(
Hi KK,
Unfortunately T-splines got acquired by Autodesk and they killed it in favor of their own Fusion 360 software. Luckily Rhino is working on their own solution using Subd modeling. There is a command in Rhino you can use called 'SubdFromMesh' (it doesn't have autocomplete, its a hidden command). This will transform a mesh into a Subd (or T-spline) geometry. https://www.instagram.com/p/Bfyr1wQBAib/?hl=nl&taken-by=thinkparametric
The problem is Rhino is still developing this feature, so it's a little buggy. Also you won't be able to do the Grasshopper part using T-splines.
I'm planning to redo the course using subd for Rhino when the feature is more mature.
KK Wong almost 7 years ago
Thank you Arie! Looking forward
