about 5 years ago by Bhargava sangam
i cant snap on line on top of the picture without hiding the picture, im using v6
Kristoffer almost 5 years ago
I'm having the same issue. Tried to use command: _sendtoback, but didn't help. Any other solution?
Hi Kristoffer,
This is a Rhino drawing order issue, what you can do is move the image just a little bit down, so the lines and the image are not in the exact same plane.
cheers!
Hi Bhargava,
Could you select the picture and apply the command: _SendToBack
This will send the image to the back of the drawing order so the lines will be displayed on top.
