over 7 years ago by Sally Hsu
The view lines stop after surpassing a certain height. Can't figure out where to fix this.
Hi Sally,
Could you post a screenshot of the issue, I'll have a look at it. This might be the case if you're using very large numbers and you're very far away from the 0,0,0 origin.
Thanks,
Sally Hsu over 7 years ago
Here's the scaled down version. The view lines are acting up in weird ways.
I'm trying to see if your script could be adapted for a pre-built building and to test it's views with a new imported 3D surrounding
Hi Arie,
Yes that is the current issue, the current structure is large.
The other issues present is that the view lines don't go 360 as well as intersect each of the towers.
Cheers.
P.S. Happy to send you the script.
Edit: Just scaled it down, works. But the view lines still intersect with each of the towers
