over 4 years ago by shikhad95
Hi, Arie. I am getting the following warning sign: 1. Invalid profile curve in loft, this may cause problems. 2. Solution exception:Index was out of range. Must be non-negative and less than the size of the collection. Parameter name: index
Arie Willem de Jongh about 4 years ago
Hi Shikhad,
It means that one of the curves you're using to loft is invalid. Usually it means it is not existing (Null or Empty) in your list.
Could you share your definition, I'll have a look. (use wetransfer and post the link, please0
