over 4 years ago by Valentina Perez
The tree branch say that the path does not exist within the tree
Arie Willem de Jongh over 4 years ago
Hi Valentina,
The panel is cut off in the image, I can't see what you're inputting into the Tree Branch component.
Could you upload a better image please? In the meantime, connect a Param Viewer component to the Dispatch component B-output. Here you can check all the names of the branches and verify them with the name your inputting from your panel.
