almost 9 years ago by Jos Noordzij
Hi I am trying to use this workflow with lists. So instead of duplicating the rule node, using a list to create multiple rules. Then I want to create the same amount of view filters (using the same list), and then assign the rules to their respective view filters, and the filters to their respective views. Problem is that I end up with some 'cross products' which i dont want: two rules are applied to one filter. Can you please explain how I can avoid this? Please also check out the Dynamo forum, I have explained the issue more in depth there. https://forum.dynamobim.com/t/parallel-list-data-flow-without-cross-products/14609 Many thanks in advance!
Jos Noordzij almost 9 years ago
