almost 7 years ago by Edmondo Rumori
Hi @6.57 What is the difference between 0.0 and 1.0 in the list? If I understood right both the values rapresent an intersection between bricks, but I still do not get what is the difference between them. Could you explain the concept once more? thx
Hi Edmondo,
So those are the indexes from the intersection lines list (we got those indexes from the Point in Brep), -1 means that there was no intersection found, the 0 means it is the first line in the list and the 1, the second one. @7.53 you see that I use those indexes to retrieve the actual line segments.
